Guest Anonymous Posted August 21, 2003 Share Posted August 21, 2003 also in a rb26dett somewhere on here i remebered reading about having to sump your gas tank and i was wondering why this mod was necessary i cant seem to find the post it was in thanx for the help Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted August 21, 2003 Share Posted August 21, 2003 Here is a post I found: http://www.hybridz.org/phpBB2/viewtopic.php?t=21272&highlight=sump Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 21, 2003 Share Posted August 21, 2003 thnx alot man Quote Link to comment Share on other sites More sharing options...
BRAD D Posted August 21, 2003 Share Posted August 21, 2003 If your car was a fuel injected to start with you should have baffles in the tank. but if you have a 240Z tank you need to do some thing to keep the fuel at the pick up at all times. And the stock lines are too small to feed a RB you will need -6 or -8, you can use your old feed as a return, and make a new feed ie. in the sump Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 21, 2003 Share Posted August 21, 2003 THANKS BRAD D YOUR CAR LOOKS GREAT MAN BUT THANKS ALOT FOR THE INFO Quote Link to comment Share on other sites More sharing options...
