76 turbo conversion, HELP ME !!!
A little back ground for you first,, i have a 76 280 turbo conversion with the following modifacations -msd,87 ecu,87 wireing harness , 87 amf,84ish distributor , 83 turbo block,turbo injectors, 76 intakemanifold and head, a custom fuel system =fuel cell, -8 lines , A.R. fuel reg. fuel filter, and custom fuel rail. pro direct port nitris centerforece2 clutch, ,,,,,,,,,,,,,,,,,,,,,,,,,,, anyways just got it all put together , and it wont run ,all i got out of it was a couple of backfires and one or two sputters, i think it is some sort of timing problem but i have double and triple checked the distributor and the valves with the pistons at t.d.c. i am fairly confident in the wireing because my electrical engineer brother hooked all that up. ,, if anyone has any tips i would really appriciate it,, thanks!!!!!!!!!!!!
