Where to plumb H20 lines for turbo
lifegrddude
Hi everyone, I'm in the middle of fixing my exhaust manifold leak and decided to swap my stock turbo out for my T3/T04B that I've had sitting around for a while. It's a water cooled unit and I was wondering where you all have plumbed the water lines for the turbo and what size fittings you have used. Where did you guys get your fittings from?
I was thinking of taking the inlet from the thermostat, but I'm not quite sure where to route the coolant back into the system. One more question, what kind of hose did you use for your water lines to the turbo? Is regular water lines okay, or f.i. lines, or did you all use stainless steel ones? Also, approximately how much hosing should I buy to get this plumb? Thanks!
John 82ZXT
