What is cost of V8 swap minus motor and trans?
The Jaguars That Run V8 swap manual (the "bible") claims you can do the complete swap, including the price of the motor and trans, for less than $1500. 2thumbs.gif
On the other hand, a few of the guys on this board probably have over $15,000 into their non-running cars twak.gif
There is an inverse relationship between cost and time on these projects. Some guys do it all themselves, use donor cars, shop the boneyards, swap stuff, and do all their own fabricating to keep the out-of-pocket cost down. But then you would need to ask them how much time they have spent on the project, which could be the hundreds of hours. Others buy new parts, hire fabricators and specialists, and pay thousands of dollars, but don't invest nearly as much of their own time.
So, you have to 1st decide how much money do you have to spend, and how much time, tools and know-how do you have to do it yourself. Somewhere between spending all your time or spending all your money there will be the right combination for you.
I suspect the guys that do it on the cheap devote the most personal time to the project and don't count their labor in the cost. The guys that spend the most money count the cost, but have more time to do other things.
That's why we see cost figures that vary between $1,500 and $20,000. Just my .02 :D
Guest Craig280z
It depends greatly on what you buy, what you build, what you do and what you hire out.
Some things to consider
JTR mounting kit including reluctor ring and speedo gears - approximately $500
Exhaust system - $200-300?
GM motor and trans mounts if you buy from your friendly neighborhood GM dealer - $200
Radiator - $50-200
Radiator Fan - $50-150
Driveshaft - $50-150
Is your new engine already running perfectly or do you need to "tune it up"?
Do you need a fuel pump?
Do you need to replace the fuel lines?
Do you need to replace the brake lines?
While your at it, are you going to put in a LSD Diff, new wheels, tires, gauges?
Probably at least another $200 worth of junk just to make things work.
I'm forgeting something but I can't remember right now. I'm in the middle of doing the swap and I found a guy locally who is an ASE mechanic and has worked at GM dealerships and is going to put my LT1 in and wire it up for approximately $600.
Craig
Guest Craig280z
I think that's what I"m going to do on the speedo BLKMGK, sometime. Can you tie it in to the engine computer or do you need a separate VSS?
Add another $200 to my numbers for the speedo.
Oh, I bought spark plugs and wires for my LT1 today, $120 for those.
Craig
