JoeinCA Posted August 28, 2003 Share Posted August 28, 2003 I was wondering if there was an easy method to make a good vacuum canister. I know the basics, but it is the details that cause problems! I could just buy one for $45.... but i havent found a local parts store that stocks them. My vacuum assist brakes arent working very well off of the intake manifold. I meant to solve this problem today... but instead i started working on my speaker boxes for my Z. I have a mig welder, though i am no welding expert yet, i could probably use it to make , or modify something, to use as a vacuum canister. Thanks for any help, Joe Quote Link to comment Share on other sites More sharing options...
Guest Thurem Posted August 28, 2003 Share Posted August 28, 2003 Any container that holds pressure would propaply be suitable. A propane canister, like the one you can buy at ACE for less than 5 bucks, comes to mind, just don't start welding on it, for obvious reasons. You also wanna get a one way valve, to keep the vacuum in the canister, and not going back into the intake manifold. Thure Quote Link to comment Share on other sites More sharing options...
Guest Bamm Bamm Posted August 30, 2003 Share Posted August 30, 2003 Just buy one of those ones from Summit or jegs they are worth the money. hope this helps Quote Link to comment Share on other sites More sharing options...
Guest benjlv Posted August 30, 2003 Share Posted August 30, 2003 a brake booster is kind of like a vacuum canister already. It has a check valve and will take a few applications of the brakes to lose the vacuum inside. Me thinks you may have a bad check valve...booster...or are just not making enough vacuum and in that case you would need a vacuum pump Quote Link to comment Share on other sites More sharing options...
JoeinCA Posted September 1, 2003 Author Share Posted September 1, 2003 I'll check to see how much vacuum pressure i have tomorrow. I need to replace all of my brake hoses tomorrow too... I hope that i am making enough vacuum to support my brakes... Joe Quote Link to comment Share on other sites More sharing options...
