Frame Rails
john kosmatka
http://www.zcarparts.com sells the floor pans and frame rails that look similar to the stock frame rail that end underneath the seat. If you are going to go to the trouble though you should cut out the stock frame rail and replace with steal tubing running all the way back to the rear subframe. Many good sites on how to do it, probably the best being Petes. http://mywebpages.comcast.net/pparaska/index.html
