Guest ON3GO Posted August 29, 2003 Share Posted August 29, 2003 ok right to it, i bought a 280ZX clutch mastercylinder... NOT a Brake Masterclyinder.... man i messed up... but i dont no where to get one, and the other question is will the 280ZX clutch mastercylinder and slave cylinder i bought work on my 280Z? thanks.. if you know of a place i can buy it at ill buy it now!! thanks again. mike Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted August 29, 2003 Share Posted August 29, 2003 I take it you want a '79 - '81 280ZX master? Victoriabritish.com has them. Part # 64-104 $119.95 I think the clutch master is the same as a 280. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted August 29, 2003 Share Posted August 29, 2003 the 82 to 83 ZX wont work? Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted August 29, 2003 Share Posted August 29, 2003 It has a different bolt pattern. I used the '79 - '81 on my 240Z Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted August 29, 2003 Share Posted August 29, 2003 ah ok.. MAN! $120 thats alot of money.. crap... Quote Link to comment Share on other sites More sharing options...
BayAreaZT Posted August 29, 2003 Share Posted August 29, 2003 If it has different hole spacing you can just knock out one of the studs and drill a hole for a new one or if you bought it new, can't you just exchange it? Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted August 29, 2003 Share Posted August 29, 2003 i went to discount auto and bought one for 45 bucks.. .. it comes in later tonight but i still cant get those damn brakes lines and fittings for those damn wilwood calipers.. Quote Link to comment Share on other sites More sharing options...
john kosmatka Posted August 30, 2003 Share Posted August 30, 2003 Check ebay, Is the 79-81zx brake master cylinder bolt on swap, what about the 83 master cylinder. Quote Link to comment Share on other sites More sharing options...
Guest Thurem Posted August 30, 2003 Share Posted August 30, 2003 Try Earls for brakelines and adaptors. My local hotrod shop carries their products. Just go to your hotrod shop and tell them what you need to do. I.e. go from 10 *1mm ( I think, double check) male fitting to 1/8-27 with a suitable length steelbraided hose. It will be easier than you think. Thure Quote Link to comment Share on other sites More sharing options...
