100 Posted August 30, 2003 Share Posted August 30, 2003 Does anyone have any experience with Picklex 20? It's "A combination metal surface cleaner, surface rust remover, 100% rust converter (including mill scale), conditions metal and provides a conductive metallurgical protective coating for long term rust protection, all in one application." http://www.ashjentech.com/picklex.htm Is there a BETTER rust converter/remover out there? Thanks. Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted August 31, 2003 Share Posted August 31, 2003 I have had good luck with SEM products that can be found at auto body supply houses. Rust-Mort is a conversion coating, probably similar to the dill pickel stuff you found. http://www.semproducts.com/sempages/semrust.html Quote Link to comment Share on other sites More sharing options...
