Guest DaneL24 Posted September 3, 2003 Share Posted September 3, 2003 I'll probably be putting an electric cooling fan into my '71 240, and I have a question about the fan wiring. Now I know the fan is turned on and off by a thermoswitch...but do I simply put the thermoswitch inline with the electric fan motor circuit...or do I have to wire it so the thermoswitch activates a relay to turn on the fan...and the actual fan motor has a different power source that is routed through the relay. I know the fan motor uses up a lot of juice...just not sure I would want all that juice flowing right through the thermoswitch. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
gramercyjam Posted September 3, 2003 Share Posted September 3, 2003 You need a relay that is activated by the thermostat. The relay then completes the circuit between the battery and the fan. Don't forget to put a fuse between the battery and the relay. Painless makes a nice little kit for this that can save you a lot of time. Quote Link to comment Share on other sites More sharing options...
