Frontpipe glowing at idle
Guest rick458
Guest rick458
I was checking for Vacuum leaks and after 15 minutes I noticed the front pipe was glowing from the manifold to the curve where the two pipes join together, this was inside a lighted garage, is this normal for an L-26? or is it running too lean?. the timing seems right, she starts easily I do have a faint pop or quiet knock in the exhaust system near #6 cylinder every 3-4 seconds (time for Decarbonizing?).
Guest Zachb55
yeah, i would suspect what nic said, try using one of those color-tune deals and i bet your problem would be fixed right up. your manifolds havent been port/polished have they?
-Zach
Guest Nic-Rebel450CA
I fattened everything up, the guys at zcar seem to think I have an exhaust valve out of adjustment I will look into that as well
Yes, I suppose if your valve was not closing all of the way then the actual combustion would blast heat out the valve. I would think that there would be a significant sound accompanying that. Not sure though as I have never had that problem :roll:
Edit: Oh yeah, you said you do hear a faint pop or knock, that could be it :wink:
