Guest kurt8394 Posted September 8, 2003 Share Posted September 8, 2003 hey everyone i'm kinda new too this board and i just turned my 74 260z into an electronic ignition, but now my rpms don't move the needle just stays at zero. how do i fix this ? by the way i have a crane ignition Quote Link to comment Share on other sites More sharing options...
Guest Nic-Rebel450CA Posted September 9, 2003 Share Posted September 9, 2003 does your spiffy new ignition have any instructions on how to hook it up to a tach? Quote Link to comment Share on other sites More sharing options...
Guest kurt8394 Posted September 9, 2003 Share Posted September 9, 2003 Well no cause i bought it off ebay but i have tried to hook it up, but then when i hook up the rpms the car won't start ??? i heard there is a adapter you can buy has any1 heard this b4 ? Quote Link to comment Share on other sites More sharing options...
Guest Nic-Rebel450CA Posted September 9, 2003 Share Posted September 9, 2003 Well no cause i bought it off ebay but i have tried to hook it up, but then when i hook up the rpms the car won't start ??? i heard there is a adapter you can buy has any1 heard this b4 ? If it isnt starting because of no spark then you may have your connection backwards. Typically there is a lead for the tach and a lead for the power, if you have those reversed the tach wont work and the car wont fire up. Quote Link to comment Share on other sites More sharing options...
gramercyjam Posted September 9, 2003 Share Posted September 9, 2003 The tach needs to be in series with the power going to or coming from the primary side of the coil. So you have 2 wires coming from the tach - one goes to the coil, one goes to the power. At least that is how the tach in my '73 works. --John B Quote Link to comment Share on other sites More sharing options...
