Do I really need a 1/2 inch spacer for hybrid turbo t4e-57?
I have a T3/T4E 57 Trim.
I tried to put the turbo on in the weekends and it fits just perfectly. It's close against the motor though so I don't know if I need some spacings between the motor and the turbo or not? Does it really matter? If it could be bad for the turbo then I'll have to have a machine shop make me a 1/2 inch or 3/8 inch spacer.
Thanks
Nathan
Yes, you want the spacer. You want to get that compressor side away from the exhuast manifold as far as possible. I think I used a 1/2 spacer on mine. If you want, you can even try to fabricate a better shield to fit in there too. You'll need longer exhaust studs by the way. I got mine from napa (they were an on the shelf item).
James
