light weight flywheel / ?
What are the benefits and/or negatives of a "Steel light weight flywheel"
Here is the description of the flywheel i am thinking of buying for my 68 327 / wc t-5 for my 73
for Chevy small block and big block standard transmission applications with internal balance. 153 tooth design for lighter mass with outstanding Quality and machining. Light design used in Dirt Track and Road race applications where weight is a plus off the corners. Faster acceleration is made by using this 16.5 lbs flywheel. Two piece Seal Crankshaft design for early model Chevy with internal balance. 10 1/2 Clutch will fit this flywheel.. The flywheel is manufactured from high quality 1045 steel and has ring gear that is made manganese carbon steel . This flywheel is machined on CNC machine center to guarantee it's accuracy
Thanks, Bob
The benefit is the motor will rev a lot quicker. Some of the horsepower the motor makes goes to accelerate the moving parts of the motor, so when you make the parts lighter, it takes less power to accelerate them. This means more horsepower is available to accelerate the car. The motor doesn't make any more power, just more of it gets to the wheels. It won't necessarily help a drag car run any faster, since traction is usually the limiting factor there, but it might. It will almost certainly help a road course car be quicker.
Negatives are cost and you have to be VERY precise with the throttle when shifting. Otherwise your shifts will be rough and jerky. I mostly do open track events with my car, and run a 15# aluminum flywheel. It really explodes out of a corner, but if you're not just right with the gas pedal you get a very rough shift, because the motor rpm changes very quickly.
John
Not much difference really. My aluminum one has a steel insert for the clutch disc to mate to, and a steel ring gear for the starter, so the aluminum doesn't gain you a whole lot. GM made a few nodular iron flywheels that were pretty light, maybe 18-20 #'s, but they're scarce and I'm not sure what application they came in. I think a lightweight steel one would be fine. They take some getting used to shifting, or at least for me it did.
John
ok cool..
one more question :?
the description says "Two piece Seal Crankshaft design for early model Chevy with internal balance"
My question is how do I know if my motor is internally ballanced? The motor is a 1968 327 from a 68 camaro. All the flywheels I have looked at say for "internal balance"
thanks again
I believe all chevy small blocks, except those using the 400 sb crank, are internally balanced. The 400 crank is too large and heavy to completely balance internally (it can be done, but was not done by the factory) and so the flywheel and harmonic balancer both have weights in them to offset the crank weight.
I beleive that the internally balanced, 2 piece main seal flywheel should work on a 68 327
Yep. All 327's were internally balanced.
Is your 68 327 a large journal steel crank motor? Fairly rare item if so, 67's were small journal, 69's they went to 350's. It probably is if it came out of a camaro. How do you have it set up? Those are great motors, I had a 68 vette with a 327/350 and it was a honker.
John
this 327 may have been out of a vette.. I bought a 72 vega for this motor and the guy I got the vega from said it was a vette 327. When I look up the #s it says "Passenger/Chevelle/Chevy II/Camaro/Corvette " but when I try to find the numbers on a vette site no matches so I'm not sure. I dont have the block number on me so I will post it tomorrow, maybe someone can help.
FWIW, I've got a 327/T5 and if you haven't driven yours yet let me say that if you're really on the throttle you'll be shifting PDQ, the first 3 gears going almost as fast as you can shift. I am not saying this isn't a good idea as maybe it's what you're looking for, just know you'll be busy shifting whether running stock or otherwise.
haha no i got the same flywheel a while back for 60$. I don't have the car running yet but I did run in to one problem. The recess for the flywheel bolts was too high and the stock clutch springs hit the flywheel bolts. So, I had to sand down the recess a bit and also grinded my arp flywheel bolts down a bit. This was with a stock clutch though, I believe performance clutches have a smaller diamater spring. The flywheel other than that looked great, but I have yet to run the car. I'll let you know how it is, cuz hopefully it'll be up and running soon.
Jason
As my understanding goes (which therefore may very well be wrong!), the lightened flywheel will help in a V-8 Z, if you are willing to put up with the drivablity issue mentioned earlier, since it is so light of a car. There will be less energy stored in the flywheel at launch so the rear wheels won't break loose as easily relative to a heavy flywheel, and as mentioned it will accelerate quicker.
