im having trouble with my hub and sub axel..
Guest ON3GO
well i packed the bearings, and put the seals in.. i torqued it to 22 ft lbs and the hub moves abit.. a tenny tinny bit, but u can move it..
i went as high as 34lbs and its the same thing.
any ideas?
btw the wheels look AWESOME on the car, its juts looks like its gonna rub on the very front of the fender...
hmmmmmmm
and they dont stick out very much either :(...
mike
I can't recall the torque required to "set" the bearings. I propably go over this when I set mine. The hub should have no play in it, even when the nut is backed off the recommended amount after setting the bearings. Some very small amount of preload will still exist.
