Guest ON3GO Posted September 13, 2003 Share Posted September 13, 2003 well i packed the bearings, and put the seals in.. i torqued it to 22 ft lbs and the hub moves abit.. a tenny tinny bit, but u can move it.. i went as high as 34lbs and its the same thing. any ideas? btw the wheels look AWESOME on the car, its juts looks like its gonna rub on the very front of the fender... hmmmmmmm and they dont stick out very much either ... mike Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 13, 2003 Share Posted September 13, 2003 anybody that could help me quick? im like 98% done... any ideas? mike Quote Link to comment Share on other sites More sharing options...
blueovalz Posted September 13, 2003 Share Posted September 13, 2003 spin the rotor as you progressively tighten the nut. You may feel a "pop" (which I have no idea what it is, but...), then back it off the recommended amount. (make sure the washer with the tab in the middle of it is in the spindle groove) Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 13, 2003 Share Posted September 13, 2003 ok ill do that.. so only 22lbs??... ill give that a shot.. should the hub fit snug without ANY movement? mike Quote Link to comment Share on other sites More sharing options...
blueovalz Posted September 13, 2003 Share Posted September 13, 2003 I can't recall the torque required to "set" the bearings. I propably go over this when I set mine. The hub should have no play in it, even when the nut is backed off the recommended amount after setting the bearings. Some very small amount of preload will still exist. Quote Link to comment Share on other sites More sharing options...
v8dats Posted September 13, 2003 Share Posted September 13, 2003 post a pic of the wheel fitment please i hope u fixed your camera. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 13, 2003 Share Posted September 13, 2003 no, no camera, im gonna get a camera today and get them developled tomorrow.. mike Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 13, 2003 Share Posted September 13, 2003 i cant get this hub to fit 100% snug.. theres the smallest, i mean smallest movement.. this is killing me.. i need to get this front end done today.. mike Quote Link to comment Share on other sites More sharing options...
