Guest monteg Posted September 15, 2003 Share Posted September 15, 2003 Guys, did a search to see the past responses , but could not find answer. When doing the JTR conversion, how many of you used or ordered JTR part #DAT-105? I have heard some use these and others not? Should I order the kit in seperate parts and avoid buying these spacers? I am installing sbc 350, w/ 700r4 trans. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Guest monteg Posted September 15, 2003 Share Posted September 15, 2003 these are the body spacers. Quote Link to comment Share on other sites More sharing options...
Guest monteg Posted September 15, 2003 Share Posted September 15, 2003 Well guys do you use these body spacers or not.....someone please help Quote Link to comment Share on other sites More sharing options...
Guest monteg Posted September 15, 2003 Share Posted September 15, 2003 Nevermind, Just found what I needed to know on Pete's site thanks anyway Quote Link to comment Share on other sites More sharing options...
QWKDTSN Posted September 15, 2003 Share Posted September 15, 2003 As far as I know there isn't a single person who has used the spacers. Some people fit them and remove them later. In general, unless you're using a Victor intake manifold, your combo will fit under the hood. Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted September 15, 2003 Share Posted September 15, 2003 I used them with my tpi/T5 swap but not the LT1/T56. I didn't need hood clearance in either case but I found that they also give you more tunnel clearance for the tranny. Quote Link to comment Share on other sites More sharing options...
Guest billy383Z Posted September 16, 2003 Share Posted September 16, 2003 i did my JTR v8 swap about 6 years ago, and I didn't use the spacers either. Didn't need the extra clearance (or the extra work!). My sbc has a reasonably tall dual plane manifold/carb induction system, and the hood closes without hitting anything. Quote Link to comment Share on other sites More sharing options...
jaime240z Posted September 16, 2003 Share Posted September 16, 2003 These are the two 0.5 inch spacers, correct? I just want to be sure because I'm going to be making a set of plates soon and not needing these will save me some work! 8) Quote Link to comment Share on other sites More sharing options...
