300zx r200 help
Hi all, I am working on a nice streetable v8 swap, and have come upon some rearend issues. I have searched but still cannot find sure facts, so any help would be great.
i have a 70 240z and recently acquired a r200 non lsd rearend out of an 86 turbo 300zx. i have the entire rearend assembly w/ both control arms and crossmember, cv shafts all the way out to the 5 bolt disc brake setup.
my question is, how much of this stuff can i use, besides the diff? is there any way to use the cv shafts without the adapters? can i convert to 5 lug using the 300zx hubs? i know that the rear control arms wont work since the geometry is different, but help would be great.
if you can answer any of the questions please do
Thank you so much
Dee
anything can be done... check out these links:
here's one for useing 300zx stub axles http://www.hybridz.org/phpBB2/viewtopic.php?t=23208&highlight= it is quite in depth and something i wouldn't try unless you are very mechanically inclined or have lots of money.
here's one for installing the 300zx turbo cv axles http://www.hybridz.org/phpBB2/viewtopic.php?t=20393&highlight= there is no chance of useing these without adapters
here's the link for the cv adapters and 5 bolt rear conversion http://www.modern-motorsports.com
here's a link to using 5 bolt front hubs http://www.hybridz.org/phpBB2/viewtopic.php?t=21046&highlight=
good luck.
