Guest TreeCutter260z Posted September 18, 2003 Share Posted September 18, 2003 I just put back in my 350 and t-5 in my late 260 after the rebuild and i have bad vibrations in the driveshaft. I just put in a ron tyler diff mount with rubber mount. The angles look perfect but it still vibrates when i get to 40 or so and increases as i accerate. it doesn't go away when i decel. The u joints are in good shape. should i have the driveshaft balanced again or a new one made? my motor is in the jtr position with the distributer about 1/2 inch away from the firewall. nothing is hitting anything . i have no clue what to do next. I need a laser pointer angle finder or something. any suggestions? thanks matt Quote Link to comment Share on other sites More sharing options...
Guest Psilocybian Posted September 18, 2003 Share Posted September 18, 2003 did you look at pparaskas site? Could the driveshaft be bent somehow? Maybe just needs to be reset. http://home.comcast.net/~pparaska/drivelinemods.htm Quote Link to comment Share on other sites More sharing options...
Guest Rick Johnson Posted October 3, 2003 Share Posted October 3, 2003 Get a digital display level and measure your drive shaft angles down to a nats but. Ideally you will be less than 3 degrees at each U joint and they will be equal front ot rear. Then get a long string or ruller and check for lateral misalignment from front to rear. Then get a dial indicator and spin your drive shaft, hope for less than .020 runout and preferably under .015. Good luck, drive shaft angles can be a real son of gun but are extremely important. How are you holding the front of your diff down under accelleration? The stock mount allows tons of deflection under accelleration ruining all your hard efforts at proper shaft angles. Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted October 3, 2003 Share Posted October 3, 2003 Also make sure that the U-joints are phased correctly(the centerline of the cups on both ends should be on the same linedrawn down the length of the shaft). Even a slight phasing problem will cause bad vibes. Quote Link to comment Share on other sites More sharing options...
Pyro Posted October 21, 2003 Share Posted October 21, 2003 I had the same problem and solid mounting the diff at both end solved the problem. Plus I moved the trans tail around in order to get the driveshaft as straight as possible. Quote Link to comment Share on other sites More sharing options...
