327 with 6 inch rods, and other crazyness
Kevin, that was very well put. Those 305 AFR heads were part of that engine's success.
Heavy Z, that's a great point. With the 6.209" rods and the 3.25" stroke, and a block at the standard 9.025" deck height, a 1.19" compression height piston would be needed. That's a fairly tight ring package. But not as tight as the 1.125" comp height my 6" rodded 406" engine has. It's a trade off though - less side load from longer rods vs tilting of the piston due to the short compression height. I doubt I'll get more than 50,000 miles out of the 406 before something else goes in anyway :) (Like an LS6).
I would also add that the Cyl. Heads & Intake Manifold used for the SBC Chevy Should've Built article were Aluminum...not Cast Iron.
If you attempted to build an engine w/those high DCR & SCR's to be ran on today's pump gas, chances are you would experience Detonation regardless of which rotating assemblies are being utilized.
Kevin,
(Yea,Still an Inliner)
