advice needed - malfunctioning headlight switch
Guest tom sixbey
Guest tom sixbey
my headlight switch is getting hot, and every now and then the lights dont come on. I know that this is caused by dirty and corroded contacts, but i'm not sure if the contacts in the switch can be cleaned or not.. - has anyone tried to service this problem with any success? - at the moment i'm a bit BROKE and i'd like to avoid buying a new headlight switch... the car is a '73Z...
I've had the problem before too. In mine the contacts were burnt - filing the contacts with a points file may help. If they are way burnt, you can try putting a little dab of solder where contact point used to be. You may need to repeat this process every once and a while when they start acting up again.
--John B
I don't think "hard" is the word. Could be tedious for some. I was a mechanical typewriter/calculator mechanic in a previous life so taking apart small stuff with lots of parts has never been a problem. I would just be careful not to lose stuff. Don't take it apart on the lawn, or over a sewer drain, in a gravel driveway, or on a shag rug, in plenty of light, etc.
--John B
Guest tom sixbey
:) hehehe - i'll take your advice! - thanks for the help..
san antonio huh? - for about a year i was the load captain for the Fedex DC-10 that went out there every night.. heavy flight!
