trany problems!!!!
cameraobsess
i have been working on this car for awile and i just got it running about 3 months ago. it has a manual t-5 and it worked great for a little bit and then started to act funny after a little while. here are the siptoms.... when i drive the shifter shakes from side to side, i can twist the shifter bar almost 90 degrees, when i shift it used to slide into the gear but now it catches on something for a split second and then gose into gear. can anyone think of something thats wrong with it? i was thinking that the shit linkage is lose or something like that but i dont really know anything about transmitions. also if the differential was starting to go bad could it cause the trany to have problems? i cant see how it would but i have reasons to beleve the diff has something wrong too. any addvice would be great thanks for the help.
Julius
when i drive the shifter shakes from side to side, i can twist the shifter bar almost 90 degrees, when i shift it used to slide into the gear but now it catches on something for a split second and then gose into gear. can anyone think of something thats wrong with it? i was thinking that the dodo linkage is lose or something like that but i dont really know anything about transmitions.
I saw a recent post talking about how the shift linkage/rods/whatever can get screwed up easily in those things. The person who messed it up fortunately had a friend who was an expert on the T-5 and fixed it for him. You might try to find the post and talk to the guy.
Julius
The only way I can see a differential affecting the trans is if the driveshaft is at a serious angle up and down or side to side. Other than that, I don't think it can affect the trans. UNLESS the gears and driveshaft COMPLETELY lock up? Of course, I'm not an expert. :(
