R200 Question
I've heard from a former 240sx owner that the 240sx had a R200 diff. Does anyone know if this is true and would this be close enough to fit a 240 or 260 Z? Basically, is this the same or similar diff that people swap in when doing a V8 swap?
As I've said before I don't have one yet but I like to get as much info as I can 'cause I will have one someday.
The 240SX indeed has an R200 differential. Unfortunately, it is the same casing design as the R230 differential (shorter and fatter instead of longer and skinner), and not the same design as the early version R200 used in the Z generations, thus not only will it not be a direct replacement bolt-in situation like the earlier R200s were (as far as mounting goes), but the half-shaft splines are different too.
