fl327 Posted October 2, 2003 Share Posted October 2, 2003 So far, im not impressed. I just installed 240mm STAGE 2 turbo clutch-guaranteeed to be good for 450lbs, well see if its good for 320 or so first. Install was regular I guess, just remember the big flywheel uses 9 bolts on the pp vs. na 6 bolt. I used a new mounting hub from Nissan, only to find out it was the same as the one I was running!!! I swapped them out anyways to be safe. Did clutch install by the book and used a torque wrench on flywheel and pp bolts. I found out what caused my clutch slippage issues as well- The time I went to the track on my old clutch when the throttle locked up on me, I warped and hotspotted the flywheel something AWFUL, the clutch still has a lot of material on it and is getting saved for a rainy day. Tranny was on the floor in an hour flat, its been a long time working from the floor on a clutch install, so it took me a while to get it back in, but for once, THE SUCKER SLID STRAIGHT IN ON THE FIRST TRY!!!!!!!!!! After all the checking and double checks were done, I took her for a drive, I think I have to adjust the pedal a little bit, it shifts kinda clunky. I was looking for a light clutch, this clutch feels dang right OEM!!! Not slipping or anything, but the clutch just doesnt have the right feel for a performance clutch, in two weeks Ill know for sure, that should be good enough time for break in, 60 miles a day commute 4 days a week for two weeks plus running errands, But I dont have a good feeling about this one...... I will be extremely upset if this thing lets me down and will be goign ACT if it does..., My back is killing me!!!!! Quote Link to comment Share on other sites More sharing options...
