Guest jeff1216 Posted October 25, 2003 Share Posted October 25, 2003 What is stock for a 1978 280Z? Quote Link to comment Share on other sites More sharing options...
RedNeckZ Posted October 25, 2003 Share Posted October 25, 2003 You have dished pistons in it, if it is still has not been rebuilt. The 280ZX came with flat tops. hope that helps. Quote Link to comment Share on other sites More sharing options...
Guest V8wannabe Posted December 1, 2003 Share Posted December 1, 2003 I believe the "N42" block had dished pistons and the "F54" had flattops. Unless your engine was swapped you should have N42 (dished pistons). Quote Link to comment Share on other sites More sharing options...
texasz Posted December 1, 2003 Share Posted December 1, 2003 As far as the F54 block goes, you would have dished pistons only if it was a turbo, it it was a non-turbo then you will have flat-top pistons. I do not know about the other blocks off hand. Quote Link to comment Share on other sites More sharing options...
preith Posted December 4, 2003 Share Posted December 4, 2003 Another way to look at it would be by the cylinder head. The P79's found on the ZX's ('79 and later) had a much larger combustion chamber and need the flattops to maintain the proper compression ratio. Phil Quote Link to comment Share on other sites More sharing options...
