what does what?????
Guest 400HP280z
Guest 400HP280z
i have a 74 early 260....my rear lights have the 2 red bars and the seperate reverse light.on the upper bar there are two light bulbs. on the lower bar there is 1 bulb.
my question is what are the upper bulbs and what is the lower bulb?
which one is taillight? which one is blinker, which one is brake? thanks i ho[pe this isn't confusing...[/img]
Guest 240hybrid
If I remember correctly the bottom (1 light) was my brake light, the top 2 light bulbs where running lights and blinkers. I didn't like the lower lense/bar only having 1 small bulb being set up for my brake lights, so i rewired my lights.
Now the top bar (2 bulbs) are running lights and brake lights...real nice and bright now :o . I used dual filament bulbs so both bulbs are lite all the time when the lights are on and when applying brakes. The lower bar with the 1 bulb is my blinker. Rewiring them was easy enough, and only takes some common sense and a little thinking as to how you want to set them up before you sauder (spelling??) it all together.
