engine builds 101
I think you need to read this
http://www.73-87.com/chp/chp.htm
then take your time and look over these
http://www.ryanscarpage.50megs.com/combos1.html
THEN
I KNOW your not going to want to hear this at this time, but it will save you thousands of dollars and lots of wasted effort in the long run,you need to understand the basics BEFORE you START SPENDING MONEY,TAKE THE TIME TO BUY A FEW BOOKS AND READ A FEW TECH ARTICLES, TO GET THE BASICS
read this , by the time you understand all the links youll have the basics
http://victorylibrary.com/mopar/cam-tech.htm
http://www.mercurycapri.com/technical/engine/cam/lca.html
http://victorylibrary.com/mopar/rod-tech.htm
http://www.zhome.com/ZCMnL/PICS/detonation/detonation.html
http://www.chevytalk.org/threads/showflat.php?Cat=&Board=UBB64&Number=397334&Forum=UBB64&Words=LSA&Match=Entire%20Phrase&Searchpage=3&Limit=25&Old=allposts&Main=397176&Search=true#Post397334
if cams are a mystery please take the time to read these, it will get you a good start
http://www.newcovenant.com/speedcrafter/tech/camshaft/1.htm
(read LESSONs 1-8)
http://www.wighat.com/fcr3/confusion.htm
http://www.cranecams.com/instructions/valvetrain/camfail.htm
http://www.mercurycapri.com/technical/engine/cam/index.html
http://www.idavette.net/hib/camcon.htm
http://www.cranecams.com/master/adjustvt.htm
http://www.centuryperformance.com/valveadjustment.htm
http://www.totalengineairflow.com/tech/valvelashing.htm
http://www.chevytalk.com/tech/engine/Cam_Selection.html
http://www.chevytalk.com/tech/101/Cam_Theory.html
http://www.babcox.com/editorial/ar/ar119736.htm
http://www.mercurycapri.com/technical/engine/cam/vtg.html
http://www.n2performance.com/lecture1.shtml
http://www.symuli.com/vw/camp1.html
http://www.symuli.com/vw/camp2.html
http://home.wxs.nl/~meine119/tech/camqa.html
http://www.chevytalk.org/threads/showflat.php?Cat=&Board=UBB64&Number=200511&Forum=UBB64&Words=your%20kidding&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=allposts&Main=200510&Search=true#Post200511
http://www.crower.com/misc/valve_timing_chart.html
http://www.speedomotive.com/Building%20Tips.htm
http://www.kb-silvolite.com/page05.htm
http://chevyhiperformance.com/techarticles/94138/
http://www.aera.org/Members/EngineTech/engine.htm
if you do nothing else buy and read these books BEFORE starting the engine build
I will save you THOUSANDS OF DOLLARS WASTED and YEARS OF LEARN TIME
http://chevyhiperformance.com/techarticles/71298/index.html
http://www.sa-motorsports.com/diyport.htm
DO YOURSELF A HUGE FAVOR
buy these books, FIRST it will be the best money you ever spent, read them, and you will be miles ahead of the average guy. youll save thousands of dollars and thousands of hours once youve got a good basic understanding of what your trying to do!
HOW TO BUILD THE SMALL BLOCK CHEVEROLET by LARRY ATHERTON&LARRY SCHREIB
HOW TO BUILD MAX PERFORMANCE CHEVY SMALL BLOCKS ON A BUDGET by DAVID VIZARD
JOHN LINGENFELTER on modifying small-block chevy engines
how to build & modify CHEVROLET small-block V-8 CAMSHAFTS & VALVTRAINS BY DAVID VIZARD
SMOKEY YUNICK,S POWER SECRETS
SMALL BLOCK CHEVY ENGINE BUILDUPS
Grumpy,
If you have a moment would you look at this build I am starting this weekend. If you see anything wrong please let me know. Thanks!
383 sbc 40 over, 4 bolt main, zero deck
Eagle steel crank
Eagle forged I beam rods w/arp rod bolts
Probe forged pistons 10.8 to 1 at 65cc w/felpro 1010 gaskets
Comp cams Hydraulic roller cam xr288hr-10
236/242-520/540 with 110 lobe sep. cam will be retarded 4 degrees to make it nuetral as comp builds 4 degrees advance into there cams.
1.50 rollers on the intake and 1.60 rollers on the exhaust
Canfield heads 200cc ,65cc chambers. cnc chambers, 3 angle valve job with intake and exhaust ported and polished.
double roller timing chain
Intake manifold is up in the air as of now
750 Holley/proform dp 73 primary jets and 79 secondary jets
All msd ignition system
Hooker super comp long tube headers
2.5 dual exhaust with h pipe.
flow master race series mini mufflers
So what do you think, any glaring mistakes or any ideas for maximizing output?
Thanks Mike
I think that looks fine, the only change Id make is to install the 1.6 rockers on the intake and the 1.5 rockers on the exhaust valves. that 2.5" exhaust may be slightly restrictive but I don,t think it should cause a problem.don,t forget that combo require you to keep the rpm range above about 3000rpm and below about 6300rpm to stay in the torque curves peak, so trans gearing and rear gearing and perhaps stall speeds if its an auto effect the combo! if its an auto equiped car a 3000rpm stall will be almost mandatory
