Guest Nic-Rebel450CA Posted November 3, 2003 Share Posted November 3, 2003 My SU's are making me mad again! I just recently rebuilt them, and they are still running great, however, a problem has now resurfaced. A problem that I was having before was the throttle being too jumpy off of idle causing the car to jump. During the rebuild, I determined that the butterfly on one of the carbs was sticking against the inner wall of the carburetor as it opened off of idle. At that time, I gently filed the edge of the butterfly and the inner bore of the carburetor and that worked beautifully for about a couple weeks. Now the carburetor is doing the same thing again! I dont want to have to keep pulling the carburetor off of the engine to fiddle with it's insides, but I cant think of what to do to provide a more permanent solution. Any ideas? (BTW, I am not up for purchasing replacements or having any expensive work done because this engine is only being used to keep the car going while I save up for my swap) Quote Link to comment Share on other sites More sharing options...
johnc Posted November 3, 2003 Share Posted November 3, 2003 Worn throttle shaft bushings. The shaft is moving around more then it should. Replace the throttle shaft bushings. Quote Link to comment Share on other sites More sharing options...
