Water cooled turbo fittings?
Ron240zxt
It depends. What I mean is that, depending on where the center section came from originally, it could be one of several sizes.
The ones I've seen are:
16mm x ?(1.5 or 2.0) straight thread (Volvo center section). Uses banjo fittings.
18mm x ?(1.5 or 2.0) straight thread (300ZX center section). Uses banjo fittings.
3/8" NPT (Some after market units like Turbonetics). Not as common on rebuilt units.
Be cautious that a 3/8 NPT fittings will seem to screw into the 16mm openings, but will not seal properly.
Where are you getting your turbo from? If your getting your turbo from a rebuilder, then tell them what you want before you get the turbo. I've used both the 16mm and 18mm. I usually get the fittings from a salvage yard and adapt them to fit.
MIne were 18mm, and it was a nissan center section, and finding the correcct fitting was a pain the ass. I got one, it was an adapter that allowed me to go to 1/4 npt or something like that.
If you go that route, be sure to put them on BEFORE you install the turbo, or yuo will be :evil::cuss:
