grumpyvette Posted November 5, 2003 Share Posted November 5, 2003 ok, here are the specs: 4-bolt 350 block bored .60 over eagle 3.75" crank eagle 6" h-beam rods wiseco forged flattops with total seal rings--12.5:1 comp. custom ground comp solid roller 251/260 duration @.50 640/653 lift with the 1.6 roller rockers 109 LSA and 106 ICL huge brodix single plane--(main reason for "low" tq??) 750 dominator carb worked over, not sure of cfm (another reason for "low" torque?) dart pro 1 215cc heads ported with 2.05/1.60 valves hooker super comp 1 3/4" headers NOS plate system full msd ignition and 10.4mm taylor wires electric water pump, electric fuel pump, and electric fan the first dyno pull went to 522hp/498tq (FLYWHEEL HP/TQ)today the motor also has stud girdles and a rev kit and i went with all forged internals so i can "spray" the poo-poo out of it. just hope the stock block holds up average torque from 3800-5000rpm is 481, with a peak of 497.8 at 4400rpm. average hp from 3800-6600 is 458, with a peak of 522.4 at 6400. volumetric eff. at peak torque is 107.3 and peak hp is 106.8 and it is between 109-111 in between. and these are corrected numbers Quote Link to comment Share on other sites More sharing options...
Zerrari GTO Posted November 6, 2003 Share Posted November 6, 2003 Hey Grumpyvette, You obviously know you stuff re: SBC engines. I have a quick question to ask.... I'm working on a Ferrari GTO replica on a 280 donor. I have a 350 w/aluminum heads off a 96 (I think) Vette. Anyway, these heads have the center bolt setup for the rocker covers and I want to find an unusual (exotic) looking rocker cover to give the engine a Ferrari "look". Please let me know if you have any sources. Thanks, J.P. Roberts Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted November 6, 2003 Author Share Posted November 6, 2003 look these over, for other ideas/options http://www.diabolicalperformance.com/diabolical406.html http://www.carcraft.com/techarticles/68999/ http://www.wpedirect.com/sportsmanengine.htm http://www.speedomotive.com/newpage6.htm http://www.rlpengines.com/chev-406.htm http://enginenick.50megs.com/81chevette.htm http://www.camaros.net/racing/SBCombo.html http://chevyhiperformance.com/techarticles/90719/ http://www.chevyhiperformance.com/featuredvehicles/67318/ Quote Link to comment Share on other sites More sharing options...
Zerrari GTO Posted November 7, 2003 Share Posted November 7, 2003 Thank you! Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted November 9, 2003 Author Share Posted November 9, 2003 http://www.scatcrankshafts.com/products02.html http://www.rpmrons.com/Crankshaft%2Cprice.html http://www.racenet.net/eng/manley-rotating.php http://www.dallasexportsales.com/RA434.htm http://schwankeshortblocks.com/id17.htm http://www.primediapowerpages.com/cgi-bin/ePages.storefront/3faec134002c33200000c0a8013a05a5/ePages/Customer/Vanity/easy/competitionproducts http://www.flatlanderracing.com/imports/crankshaft_eaglemenu.html a few places to buy parts Quote Link to comment Share on other sites More sharing options...
