Guest JAMIE T Posted November 16, 2003 Share Posted November 16, 2003 Hey guys, any of you auto body/paint guys know what is the tempature range for spraying PPG DP primer? It's in the 50's in Richmond these days and I want to get it primed ASAP. Quote Link to comment Share on other sites More sharing options...
datsunlover Posted November 16, 2003 Share Posted November 16, 2003 Take a look on the side of the can.. it should say what temp's its good between. A friend of mine says it should work though 50 is at the lower end of the range.. any colder and it will do strange things. Quote Link to comment Share on other sites More sharing options...
Guest freakypainter Posted November 16, 2003 Share Posted November 16, 2003 it should spray fine just use the lowest temp reducer like DT865. give it a little longer between coats and it will take longer to dry in such cold temps. You could always rent a propane space heater to heat up your garage, then shut it off (you wouldnt want an open flame while spraying) then after the over spray clears out fire it back up. Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted November 17, 2003 Share Posted November 17, 2003 Thats exactly what I needed to know, thanks Racer X. We will have a couple of high 60's low 70's days this coming week, I'll schedule to spray it then. Quote Link to comment Share on other sites More sharing options...
