cleton-z Posted December 4, 2003 Share Posted December 4, 2003 hey everybody well i just put a 83zxt engine into a 72z and everything went smooth until i wanted to start it well first the fuel pump would not work so i spent all day tring to figure it out so i finally took it out of the car and took it apart and cleaned it so now it works great well i tried to start it and i found that there was no spark when the engine was turning over so i went into the archives to see if others had the same problem but no one wrote about haw they fixed the problem i thought that when you turn the key to start nothing would get power except the starting system so i have to test that when i get back if anyone has sume input it would be greatly apreciated thanx Quote Link to comment Share on other sites More sharing options...
fl327 Posted December 4, 2003 Share Posted December 4, 2003 check voltage to coil with key on. see if there is voltage, should be. if not bypass coil transistor and apply direct 12v to + if it starts, bad connection at key switch no start-module is bad, coil perhaps(ive not yet had a coil go out on me) make sure both relays go "click" with key on power, if they do not click or click too much, check em. check cranking voltage, if below 9v-ecu wont let the show go on. Quote Link to comment Share on other sites More sharing options...
