DIY decarbonizing?
TomoHawk
  • 3 weeks later...
Guest Nic-Rebel450CA
Are you talking about with the head on or off? If you are talking about while running the engine, water misted into the intake works pretty well. Not how much it will leave behind, but it can get quite a bit out.
Service stations do it with the engine in the car. The Book says you hook up a tube from a can of the liquid stuff to the vacuum port of the throttle chamber. I never heard of using water to decarbonize the engine.
Is there a way to tell how bad it is?
Water helps, but it is probably not the most effective way. The steam helps clean things out. I dont know of any way to tell how dirty it is, other than pulling the head. A smog check will point towards carbon deposits, but it wont tell you how bad.
