How to change jets on edelbrock/carter 4 barrel?
Heavy Z
I just got my first carter carb - it's identical to an edelbrock 4 barrel and my experience is with holleys so I could use some advice, I need to change the secondaries. How is it done? I took off the air cleaner and looked around the carb but I guess I'm missing something. Thanks. :cheers:
Yeah, these are like the old AFBs. You'll have to remove all the top screws (about 8 of them I think), lift off the top plate and you'll see the jets at the very bottom of the bowl. I believe the needles come out with the top, so care is required in placing the top plate back onto the main body when done, making sure everything is lined up and needles are properly inserted in the jets.
