Radical Body Kits
Guest Pharaoh
Guest Pharaoh
I am trying to find a place to find a nice radical body kit for a V8 280z. ..its hard to find IMSA flares(or the supper wide body one's they use to race) and I want something diffrent without having custom bodywork done even though I know a little will have to be done. Also, I want to know other wheel offsets and bolt patterns match a 280z that I can get in a 245/16 wheel without moving the shock towers in the rear. All suggestions are welcomed.
A 245/16 set-up can be had with stock diameter springs and no flares. If this is the size of tire that you want to use with large flares, then the wheels will require a lot of offset, or, you may want to use wider wheels/tires to avoid too much of a gap between your tires and the bodywork. Radical, to me, implies wheel sizes in the 11"-12" width, which would fill out nicely the wheel openings of the larger flares.
