how to figure rear end ratio
I need some knowledge. When I turn the wheel
one compleat turn , the yoke turns 1 1/4 How do I tell what gear it is ?
This is a monte carlo rear end for my 48 chevy.
My Z is unfortunatly on the back burner,due to the shop,but not to much longer!! www.speedtechcoatings.com
[This message has been edited by takman57 (edited September 27, 2000).]
Depends..... is the other wheel being held still, or is it turning the same or opposite direction when you turn one wheel?
If they are both turning the same direction and the same speed, the relationship is 1:1 ie. you would have a 1.25:1 rear end(Not likely!).
The opposite wheel is probably sitting still, in which case the relationship is off by a factor of 2, or a ratio of approximately 2.5:1.
Make sure the opposite wheel is not turning when you do this, then double the number of turns of the wheel to get the ratio.
Morgan morgan@z31.com
http://carfiche.com
http://z31.com
