Guest exahertz Posted January 8, 2004 Share Posted January 8, 2004 Not quite sure how to go about bleeding the clutch line and installling a new master and slave cylinder for my clutch. Looking for a good tutorial for a 280zx. I havent been able to find one at all much less with pictures. I'd like to find one with instuctions a 4th grader could read seeing as I'm new here. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted January 8, 2004 Share Posted January 8, 2004 Do you have a Chiltons or Haines manual. It is a very simple process, but will take a lot of typing to show you..... Tim Quote Link to comment Share on other sites More sharing options...
Guest rick458 Posted April 18, 2004 Share Posted April 18, 2004 I know it takes A very long time to bleed both of them, I replaced my Master and Slave Cylinder on the Clutch I should have bench bled the Master better before bleeding the whole system I just filled the Master up tubed it in to the slave and had the wife pump the pedal while I had the bleed fitting on the slave slightly cracked and my thumb over the fitting. took an hour total in 2 shifts 45 min to get Most of the air out and fluid in, and flush the garbage in the lines out, then let it settle for 30 min and bled it 15 more minutes. It works good but bench bleeding would have saved tons of pumping/ time Quote Link to comment Share on other sites More sharing options...
