M30 injection experiment.
Mack
well, my local ecology pick n pull had a half price sale today and they also had an M30. So, i went there and pulled EVERYTING to make the swap work! I got the wiring harness, brian box, all the sensors (MAF, dist, coil, water temp, everything) connected to the harness, and the injectors. all for $80. Anyone know where I could get pinouts and wiring diagrams for an M30? it is fully sequential. i opened up the ECU and it had 6 little injector drivers, how cute! only probelm is it had a very minor injector fire, some of the wires are crispy and a little melty.
I grabbed a few plugs from a maxima to wire into the harness at the bad points. I also grabbed maxima injectors, because the max had the recall done and the injector numbers were the same between the max and infiniti. the max had flow thru injectors like the M30. but the max was definately a batch fire system, and the M30 definately sequential. This should make for an interesting project. I plan on adding a high comp. head, cam and a header at some point. any suggestions or comments?
McAdam
