Guest 4.3L 280z Posted January 18, 2004 Share Posted January 18, 2004 I got my 75 280z finished today and there is a popping sound coming out of the exhaust at idle and when rpm is kept constant every once in a while and sometimes it does it repededly for a few seconds, it does not do it when revving it up. the valves have been udjusted, checked plugs, checked timing, tuned carb, did a search on the site to but everyone else who has this problem only had it when letting off of the gas. Also I have a 4 barrel 390cfm carb and 3-into 1 header with twice pipes Thanks, Nathan Quote Link to comment Share on other sites More sharing options...
Guest 4.3L 280z Posted January 19, 2004 Share Posted January 19, 2004 I also noticed that it doesn't do it a whole lot until it gets hot and it gets worse. Quote Link to comment Share on other sites More sharing options...
GAZRNR Posted January 24, 2004 Share Posted January 24, 2004 I had a similar issue on my FI 78Z & had an experienced Z mechanic look at my car for some advice. He clalled it a lean pop and cleaned it up with an adjustment to air flow meter. With a carb you may want to richen it up a bit by backing out the idle adjustment jets on the front of the carb a 1/4 turn each and see it it goes away. Quote Link to comment Share on other sites More sharing options...
