Guest Craig280z Posted September 9, 2002 Share Posted September 9, 2002 Can anyone tell me where to hook up the radiator fan and the torque converter to the computer on a 95 LT1 from a Firebird? Also, how does the port hook up that allows access to program the computer. I still need to hook that up too so I can use LT1 edit and adjust everything. Other than that, my car is ready to roll!! Man that sucker flies. Even with the open 3.7 differential and 195/70/14 tires, it is pretty quick. Thanks, Craig Quote Link to comment Share on other sites More sharing options...
Tim240z Posted September 9, 2002 Share Posted September 9, 2002 Craig, The fan is hooked up by using the wire from the PCM to the Earth on the fan relay (the PCM provides a ground to complete the circuit). Sorry don't know about the auto Trans. All you need from the PCM for the DL connector is the 'serial data' line and the earth. Make sure you have a good ground for the earth. If you don't have a diagnostic connector, just about any OBD1 GM car is compatable. I got mine from a Cavalier. Can't remember for sure which pin the serial data goes to, but I think it's the "M" pin on the plug. BTW, mine is a 94 Z28, but I would imagine the wiring to be the same. Tim Quote Link to comment Share on other sites More sharing options...
Guest Craig280z Posted September 9, 2002 Share Posted September 9, 2002 Hey Tim, Thanks for the reply. Any idea which wire from PCM goes to the fan? Thanks, Craig Quote Link to comment Share on other sites More sharing options...
Tim240z Posted September 9, 2002 Share Posted September 9, 2002 Craig, Depends. There is a primary and secondary fan wire (if running dual fans). I believe the primary one (I am only runnning 1 fan) is the # 16 green wire from the red PCM connector,but I am doing this from memory. I can check my FSM manual this evening. Both wires for the fan are green! Tim Quote Link to comment Share on other sites More sharing options...
Tim240z Posted September 10, 2002 Share Posted September 10, 2002 Ok Craig, Here you go! Data Link Connector (DLC): Cavity "A"= Ground (Blk/White) Cavity "B"= Diagnostic Request (White/Blk) Cavity "G"= Program input, keyless entry module Cavity "M"= Serial Data Line Fan Wiring: Red PCM Plug: Cavity "10" Secondary fan relay control (DK Blue) Cavity "11" Primary fan relay control (DK Green) Remember, these fan wires provide grounding, not power for the relay. Hope this helps, Tim BTW, while I have the FSM out, here's the auto trans wiring: Black PCM plug: #7 (lt grn) 1-2 shift control solenoid #13 (gry/wht) 3-2 shift control solenoid Blue PCM connector #2 (Lt blue/wht) pressure control solenoid low #11 (tan/blk) TCC solenoid control #28 (yel/blk) Trans fluid temp sensor signal Clear PCM plug: #15 (orn/blk) PNP [park/neutral position] sensor #16 (red/blk)pressure control solenoid high. Quote Link to comment Share on other sites More sharing options...
Guest Craig280z Posted September 10, 2002 Share Posted September 10, 2002 Tim, If you don't mind, I would appreciate it if you could check for me. I have only one fan and it is a single speed Taurus fan. The car is running very cool with the Griffin radiator, even in stop and go traffic on a 95 degree Alabama day. I am pleased with the cooling system. Thanks Craig Quote Link to comment Share on other sites More sharing options...
Guest Craig280z Posted September 10, 2002 Share Posted September 10, 2002 Hell Yes! Thanks Tim. BTW, I love your gauges. What series are they and did you get an electronic speedo? Thanks Craig Quote Link to comment Share on other sites More sharing options...
Tim240z Posted September 10, 2002 Share Posted September 10, 2002 Craig, You're welcome. At least I know that I'm getting my money's worth out of the FSM!! My gauges are Autometer Ultra lites. Originally I bought a mechanical speedo (back when I was doing the Carb/automatic trans setup), but I sold the speedo and trans temp gauge and just last Thursday got me new electronic speedo from Summit. I had soiled underpants issues when I saw the price on those things!!!! $200 for a bloody speedo....outta control, but I paid it Tim Quote Link to comment Share on other sites More sharing options...
