what are these?
Guest 4.3L 280z
Guest 4.3L 280z
I'm getting a new coil and there are two boxes around it I was wondering about. One has three circles on it and the other is under the coil. It is a 75 280z, do I need these? And also on the other side of the car there is somthing with a couple of wires running throught it and has a cover over it thats cracked, would think it was a light but if you take the cover off the wires are just joined together inside, it doesn't make any since why its there.
ok.. the cracked box thing is your fusible links, they are basically 25 year old technology for fuses. easily converted. maybe the box by your coild your talking about is a resistor? a ceramic piece with a spring inside and two wire posts on each end? other wise your going to have to descirbe it better, what brand is the coil?
-Ed
