warrenp Posted January 29, 2004 Share Posted January 29, 2004 for those of you that have been reading my last post. i have 2 t5 trannys one is a ford world class t5 the other is a non world class t5 from a chevy so that question is, is a world class all it's cracked up to be? NWC or WC? Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted January 29, 2004 Share Posted January 29, 2004 A WC can handle more torque than a non-WC. But even the WC can only handle about 320 ft lbs. Here is some more info: http://v8rx7.com/trans.htm http://www.moderndriveline.com/Technical_Bits/t5_history.htm Quote Link to comment Share on other sites More sharing options...
Pyro Posted January 29, 2004 Share Posted January 29, 2004 I have used both and could not tell the diference. In either case, slow shifts and normal width tires will save the trans. You can also use slicks but use a brake linelock to hold the car still while letting out the clutch a little to preload the drive line gears before dumping the clutch. I ran 1.5 second 60 footers and over 130 mph in the 1/4 mile using both WC and Non-WC transmissions. It is more important to use the V8 transmission and not the V6 transmissions. But I repeat, slow shifts and no clutch drops unless a line lock is used to take up driveline slack first. After my burnout in second gear, I pull up to the starting line and hit the linelock. Then I rev the engine to 5500 and let the clutch out just a bit. The engine pulls down a bit when the clutch engages. Then I dump the clutch on the last yellow and hang on. I'm sure my engine is making 400 ft lb of torque without N20 then aother 200 ft lb on the spray. So a transmission with a 300 ft lb torque rating can handle 600 ft lb if driven carefully. Quote Link to comment Share on other sites More sharing options...
Heavy Z Posted January 30, 2004 Share Posted January 30, 2004 Pyro has just made my point and then some. I've got somewhere in the neighborhood of 390tq and my nwc T5 feels no different in 1 1/2 years of hard (but transmission-conscious)driving. Quote Link to comment Share on other sites More sharing options...
