Fuel Pump HELP!
majik16106
ok, so when i first tested the Z, we ran almost no boost, used the stock fuel pump (just to make sure the car could drive), SOOOO, now that im upping the power and its going into its final stages of driveline completion, i need to find the right pump, i had asked about this once but i cant find it. So its a 7m motor, 550cc injectors. I have an afpr, so what pump are you guys using? im using the stock fuel tank (originally Id figure Id use a walboro supra pump, being i have a supra motor, buts its inline and the Z is external.. so.. what all are you guys doing?
I am running the Walboro GSL392 external pump, its the external version of their popular 255lph model. Good for 600hp. Do a search under the "Turbo Supercharger" section and go back a few weeks, I did a decent write up of installing this pump on my L28ET.
Hope that helps! Glad to see the 7M is alive and kicking and ready to pounce!!
Yasin
