Guest xmalangasx Posted February 6, 2004 Share Posted February 6, 2004 i'm looking into buying an '82 280zx, i was wondering if anyone could let me know about some things i should lookout for... thanks Quote Link to comment Share on other sites More sharing options...
Guest comeandzpa Posted February 6, 2004 Share Posted February 6, 2004 RUST! Check the frame rails, battery tray, spare tire compartment, and fenders, as they were prone to major rusting....my frame rails were cracked in the middle when i bought the car, which I didn't know....welding them back together can be expensive. Quote Link to comment Share on other sites More sharing options...
Guest zedixe13 Posted February 8, 2004 Share Posted February 8, 2004 Hi , check for :noisy rear axle , clunky rear axle shaft , noisy 5 speed in neutral at idle ( second shaft bearing won't go long ) or pilot bearing on clutch . Leaking injectors , cracked exaust manifold . The engine are pretty tough and can go on for ever if maintained . Go for the one with the best interior you can find , cause Nissan is just waiting for you at the corner to get your $$$ , prices are ridiculous if you're on a tight budget . Rubber seal , specially t-top ( $ 500. each here in Canada ) and perfect dash are impossible to find used in good cond. Other than that , rust is the biggest problem and a good body with a nice interior is always a prime candidate even if there's mecanicals problems. Ben'Z in Quebec city under 4 feets of snow . Quote Link to comment Share on other sites More sharing options...
