Doug71zt Posted February 10, 2004 Share Posted February 10, 2004 Need a quick answer before starting work on my F54 block. With the LD28 crank and an 87 mm bore - will I have any rod/cylinder wall clearance issues? How about rod big end / engine block area? I'm using L24 rods with the group purchase Ross pistons. Norm, Rags, Anyone? Thanks - Doug Quote Link to comment Share on other sites More sharing options...
Guest norm[T12SDSUD] Posted February 10, 2004 Share Posted February 10, 2004 I am running an 86 mm bore and the only clearance issues that I had were on the back of the crank where there are raised stamped numbers. I had to shave the crank slightly due to piston to crank interference. However, that shouldn't be an issue with your motor since you are using 240 rods. Later,norm Quote Link to comment Share on other sites More sharing options...
speeder Posted February 11, 2004 Share Posted February 11, 2004 Hey, I was just going to ask this same question before my engine buildup - 87.5mm bore, L24 rods, custom forged pistons with rather short skirts. Right now I'm thinking about test fitting the pistons/rods without rings to check the rod - to - block and crank -to - piston clearance. Think I should forgo this mockup and just build it? If there are block clearance issues which cyllinders are most likely to have the problem? Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted February 11, 2004 Share Posted February 11, 2004 The only interfernce problem I had was one rod bolt hitting the thin sheetmetal splash guard covering the wire mesh inside the block where the breather tube enters the block. All I did was concave it a bit, and it cleared it fine. Quote Link to comment Share on other sites More sharing options...
