Help! water jacket holes not lining up! Grumpy?
Figured I had to rephrase my earlier question since I didn't get any responses :shock: ...
I have Canfield 195 heads that I am putting on my 400, and I was checking them with the head gaskets. The holes in the gaskets line up perfectly with the holes in the block. But when I checked the heads, there are 2, what look like water passeges in the head, that are about 50% blocked by the gasket/block. So I need to know if this is a problem or not. I can angle the holes so they do line up ok. I'm just not sure if I should. Here is a picture of the passages I am talking about:
http://f1.pg.photos.yahoo.com/ph/demidion/detail?.dir=/My+Z+Cars-My+75+280Z+with+a+377+-2&.dnm=554e.jpg
Thanks!
You are about to drop off the page, so I'll chip in with a suggestion, although it may not be too much help... Why not give Canfield a call & talk to them? They should know, and also be able to explain why a couple of the steam holes are not drilled in the head. Those bother me more than big holes that are half open. (The picture shows both steam holes drilled in the center, but only one of two in the other spots).
To quote the Canfield web site "Customer is KING at Canfield, we appreciate the opportunity to furnish you with your cylinder head needs. In fact if your not satisfied, please call 1-330-533-7092 and ask for John, as they say "The buck stops here." Sales 1-330-533-7092 Fax 1-330-533-7063."
on the street , if your running a 400 block,youll NEED to drill STEAM HOLES, contact canfield, edelbrock,AFR,DART,ETC. for the detailed instructions or IDEALLY send the heads to them for the work,(so you don,t screw it up) on a 350 this is not necessary
steam hole locations if your running a 400sbc
(these instructions are from PRO heads yours might be slightly differant) notice the angle and depth of the holes varies between the pro and AFR heads
look around carefully
HERES WHAT AFR SAYS
400 BLOCKS:
Steam holes are recommended for all 400 block applications. Use a 400 Gasket as a template and drill the three holes, nearest the spark plug side of the head, straight down. The other three which are very near the head bolt holes should be drilled at a 30° angle away from the bolt hole. The center hole will intersect water about 1" down and the two outboard holes to a depth of 2 1/4". Use 1/8 drill.
Sorry- You guys have better eyes or bigger monitors than I've got, because when I look at the picture in the link I see only 4 steam holes, not 6.
If the two by the head bolt holes next to the end cylinders are there, I sure can't see them.
Maybe someone on Canfield's assembly line is using stealth drill bits, or they made a design change, or my sight is rapidly failing.
Since my memory is going as well, there are normally 2 steam holes at each siamesed pair of cylinders, right guys????
Guys! :shock:
Yes you are correct! When Canfield designed the heads they put a lot of reinforcement into them. That ends up meaning that there are no passeges to drill into where the other 2 steam holes would go. I know people that have used Canfield heads on 400s and have had no problem with just using 4 steam hole instead of 6. I assume that it aloows enough water to flow to prevent the hot spots.... but I am still going to use "water wetter"!!
