350 V8 in a 79 280z
I have an old 74 350 V8 out of a Blazer. The engine will need some work. I have already ordered the JTR guide on the swap but I am curious if there are any tips out there. I appreciate any information you could give
buy these FIVE books, it will be the best money you ever spent, read them, and you will be miles ahead of the average guy.
HOW TO BUILD THE SMALL BLOCK CHEVEROLET by LARRY ATHERTON&LARRY SCHREIB
HOW TO BUILD MAX PERFORMANCE CHEVY SMALL BLOCKS ON A BUDGET by DAVID VIZARD
JOHN LINGENFELTER on modifying small-block chevy engines
how to build & modify CHEVROLET small-block V-8 CAMSHAFTS & VALVTRAINS BY DAVID VIZARD
SMOKEY YUNICK,S POWER SECRETS
then read and understand these
http://www.torquespecs.com/gmfs70-88chv8.htm
http://www.newcovenant.com/speedcrafter/tech/camshaft/1.htm
http://www.unofficialbmw.com/all/misc/all_oilfaq.html
http://www.fernblatt.com/longhurst/engineoil_bible.html
http://www.babcox.com/editorial/cm/cm99828.htm
http://www.babcox.com/editorial/us/uhs89734.htm
http://epics.aps.anl.gov/asd/me/FilmPressureDrop.html
http://www.pix.za/manex/lube.htm
http://www.mr2.com/TEXT/synth_oil.txt
http://theengineshop.com/content/tech2.pdf
http://www.cfivevette.com/forums/showthread.php?s=&threadid=2683
http://www.cfivevette.com/forums/showthread.php?s=&threadid=2809
http://www.chevytalk.org/forums/Forum64/HTML/012480.html
but heres
some places to buy engine parts at reasonable costs
http://www.procylinderheads.com/
http://www.enginekits.com/
http://www.racepartsstore.com/proaction.html
http://www.dirttrackthunder.com/
http://www.schwankeshortblocks.com/id117.htm
http://www.sdpc2000.com/cart.asp?action=catalog_start&catid=120
Guest greimann
The JTR motor mounts and trans mount will not work with the ZX. You will have to install the motor "straight down" and the transmission will also have to be a concoction of your own, depending on what type of transmission you install.
If you have the power steering box, you are going to have a tight fit on the left side exhaust manifold. The best fit is to use a Chevy manifold, casting #364747.
