Hitman47 Posted February 26, 2004 Share Posted February 26, 2004 what is the hp rating on the 5.0 block? Where is the best place to pick a 5.0 block at? What are the best heads for the buck? What is the best aftermarket intake? Edelbrock, Holley? Basically i have lots of chevy experience and barely ford, where is the best place to shop for ford parts? Where is the best ford "tech" web page? Chad Quote Link to comment Share on other sites More sharing options...
Guest dpiatkin Posted February 26, 2004 Share Posted February 26, 2004 Hitman, the output for a standard 5.0 block for 89-93 Mustang is around 225 hp and 300 ft.lbs. of torque..... the best source is probably your local wrecking yard, whole wrecked mustangs go for cheap ! or you can get a motor and tranny assembly, already pulled for around 750.00 in my area (w/ harness, accessories etc...) Your best heads for the buck would seem to be the "Air Flow Research" 165 cc Aluminum heads, here is a great article using these heads and a 1990 5.0L sbf. from a mustang http://www.carcraft.com/techarticles/116_0307_ford/index.html this is a great article for a 5.0 build up !!! Here is another great website for 5.0's http://www.jason.fletcher.net/tech/specifications/specs2.htm best of luck and document thoroughly all you do with a ford small block, as not many have done this swap and we could all use this help !! Quote Link to comment Share on other sites More sharing options...
