S2000 Wheels?
Guest jknust
I have some extra Honda S2000 wheels sitting in storage.
I was wondering if anyone else has ever used these on a 240Z? Would I have any luck with a decent fit using the 5 lug conversion kits here? Any specific one?
Honda S2000 Wheel Specs:
Front:
16" x 6.5" w/55 mm offset 17.5 lbs
225/50/16
Rear:
16" x 7.5" w/65 mm offset 18.5 lbs
245/50/16
My car is a 72 240Z with coil-overs. Thoughts are appreciated.
I have 17x7 +38mm offset wheels on my 240 - with coilovers.
Front - Z31 hubs (+19mm change in offset) with a 5mm spacer. I could actually go with 5-10 mm more in spacer, but would have to get longer wheel studs.
Rear - custom rotor mount/bolt-on spacer. Stub axles are drilled 5-lug. Spacer is 45 mm thick, but I removed the brake drum so had to add that thickness to the spacer.
Hope that this helps you a bit - Doug
