Definition of Track Width Measurements
This measurement may be recorded by placing the tape measure in a number of postions across the tracks. The selection of tape placement will depend upon the quality of the track as it appears at the scene. Chose the tape placement that would result in the most accurate recording of the track width. Look for the most well defined edges of the tracks, and measure across these points.
Each of the following tape measure placements will produce the track width:
Center rib on one track to center rib of the other track.
Outside of one track to inside of other track.
Inside of one track to outside of the other track.
Inside of one track to inside of the other track plus the width of one track.
Outside of one track to outside of the other track minus the width of one track
