Correct part numbers for side window channel 'fuzz'
Tim240z
Just for informational purposes:
I replaced all the window channel seal 'fuzz' on the driver and passenger sides of the 240Z. I got the rubber window channel from JC Whitney.
Part number:18ZX4873W
http://www.jcwhitney.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10101&storeId=10101&langId=-1&productId=170759&mediaCode=ZX&appId=505154
ALL RUBBER WINDOW CHANNEL
Stops leaks
Available in many sizes
Duplicates original sizes, shapes and construction
Unbeaded channel with flocked or coated linings. Millions of fibers are electrostatically driven into adhesive on rubber and then cured. Soft and dense for flexibility, low friction and long life. Seals out weather, eliminates window rattles and enables window/window regulators to function properly.
(DD) Commonly used on General Motors vehicles.
Style 20, All Rubber Window Channel, A=7/16", B=1/2", C=3/16" to 7/32", D=1/2", Overall Length 8 ft.
One is not enough to do both sides. You'll have to order two, and will have about 3/4 of the second one left over.
Tim
